You've been reading about it, talking about it, maybe even trying it. Gear Technology has jumped aboard it feet first and begun a voyage on the World Wide Web. Beginning with this issue, an electronic version of the magazine will be online. For those of us who still find the fax machine amazing technology, this is a great leap.
Over the past decade, the wire electrical discharge machine (EDM) has become an increasingly important tool for machining non-standard shapes. It has even been used to cut gears and gear cavities for plastic molds. While generally accepted as a quick and versatile method for cutting spur gears, the EDM gear has lacked the precision of a mechanically machined or ground gear. We suspected that many of the errors associated with these gears were caused by inexact setup procedures, poor tool path control and improper cutting parameters. We decided to test the potential for the wire EDM to make the most accurate gear possible.
Earlier this year, a relative of mine, Sidney Mandell, tragically passed away. I had the good fortune to serve with Sidney on the Board of Directors and the Executive Committee of the Machinery Dealers National Association (MDNA). Though he started before me, his MDNA career and mine overlapped for about 2 years. As I think back on the many things I learned form him, one of his favorite phrases keeps come to mind: "We walk in the footsteps of those who have gone before us."
AGMA has an excellent Training School for Gear Manufacturing. It's a great product providing a great service to the gear industry. Thus far we've educated 117 employees from 71 companies; students range from new hires with no experience to company presidents. Essentially every class since December, 1992, has been sold out.
